Bent bars and fuel lines
JDC
Conwy, Wales
Do you know if 2006 R1200GS handlebars will fit my 1150GSA?
Also, what inside diameter are the fuel lines (balance pipe) and lines to/from the fuel tank.
Many thanks,
Jonny
Many thanks,
Jonny
Balance pipe fuel hose is 6mm i/d x 11mm o/d
External fuel supply and return hose is 8mm I/d x 13mm o/d.
Rockster bars fit with only slight modification of the hand guards. They also take the GS controls and heated grips as a straight swap
