moonhead911 Registered user Joined Mar 28, 2015 Messages 631 Reaction score 1 Location Sheffield Feb 10, 2017 #1 best way to fix my left heated drip thats shorted i was thinking about just soldering the broken element up but i dont know if that will hold up to the heat
Popell Well-known member UKGSer Subscriber Joined Apr 27, 2009 Messages 3,618 Reaction score 146 Location Coming to a scene near you......, UK Feb 10, 2017 #2 If you get solder to hold it will have no probs with the heat. I had to dig out some plumbers flux to get good adhesion. Lasted another year then bit bullet and replaced it when it went again
moonhead911 Registered user Joined Mar 28, 2015 Messages 631 Reaction score 1 Location Sheffield Feb 10, 2017 #3 Popell said: If you get solder to hold it will have no probs with the heat. I had to dig out some plumbers flux to get good adhesion. Lasted another year then bit bullet and replaced it when it went again Click to expand... did you buy new or second hand thanks
Paul Young Under-used member UKGSer Subscriber Joined Jan 6, 2002 Messages 5,695 Reaction score 2,262 Location Preston UK Feb 10, 2017 #4 Solder it, place a strip of insulation tape over once you've checked it works and put a new grip over the top. Job done
moonhead911 Registered user Joined Mar 28, 2015 Messages 631 Reaction score 1 Location Sheffield Feb 13, 2017 #5 iv solders it. it seams to be working fine just have to see how long it last
Popell Well-known member UKGSer Subscriber Joined Apr 27, 2009 Messages 3,618 Reaction score 146 Location Coming to a scene near you......, UK Feb 14, 2017 #6 Sorry for late reply, bought new, fitted same time I had the clutch done
