Beta testing a new throttle balancer
Steptoe
Him/Bloke/Fella.
S/W London.
And so far i'm very impressed. The Harmonizer. Suitable for all twins, 1100/1150/1200 and airheads. ( you can do 4 cylinder models if you know what you're doing ;)).
Very instinctive to use, and fast. Shows the engine revs alongside the balance readout.
Plus there are a couple other functions which i've not needed to use so far, vacuum gauge, LED light, and flashing beacon (?).
So before you throw your money away on a twinmax (which aren't very good anyway and a pain to use), wait a bit for these to appear.
Bare in mind the unit in the pictures is a beta model, which is still being tweaked and improved, and not the finished product .
me neither, all this complication to balance an engine,,
however,,can you ride the bike with it switched on, ?
a function i found handy with the twinmax, as a balanced tickover isnt always a balanced mid range
Pretty good design. Does the smiley come up on balance?
The website is parked, any idea of cost/release?
looks ok, not sure I would replace my home made manometer with one though!
it's a bit more portable and a lot less messy.
It's not complicated, it's simpler than a twinmax. . It can be be used on the move.
Smiley appears when close to balance :D no idea of cost or release date.
Throttle Balancer
Hi,
I know this is an old post as such but is this throttle balancer
available now?
Anyone provide a link please:beerjug:
Thanx,
Deano
Try searching on "Harmonizer" there is therad with more detail on how to get one.
I felt so cheated with mine; until I realised that was because it was so quick and easy to use ! The difference between 2 big singles being as synchronised as possible, and just "within acceptable tolerance" is immense.
