Beta testing a synchronising unit
Steptoe
Him/Bloke/Fella.
S/W London.
I've been testing a couple of these units and i'll bring them along for you to try out - I have a pre-production unit and a later pre-release unit.
Be interesting to see if you can find any problems and your feedback on using them :thumb
<iframe width="560" height="349" src="http://www.youtube.com/embed/ph5VF4xDxsA" frameborder="0" allowfullscreen></iframe>
The Harmonizer
The Harmonizer is a small, portable, battery-powered, Vacuum Multi-Tool intended to aid powersports engine tuning and diagnostics. It works for both carbureted and fuel injected motors. In addition to vacuum and RPM measurements in two distinctly different modes, a few utility/convenience features have been included
Functions
The Harmonizer has two Vacuum modes that both include tachometer functions. Balancer mode and Gauge mode. The Harmonizer measures the period of the vacuum pulses to calculate RPM.
Balancer mode displays the difference in vacuum at the two ports. There is a center-zero representation similar to an analog meter, and a numeric representation in the range of +/- 999mbar. A smiley appears if the vacuum difference is 0 +/- 25mbar. In Balancer mode the tachometer is calibrated for 4-stroke motors with one cylinder/intake. For 2-strokes or motors with 2 cylinders/intake you must divide the tachometer reading in half.
Gauge mode is a heavily damped vacuum gauge, intended to measure vacuum on intakes that support one or two cylinders. Only one Harmonizer port is used. The other is left unconnected. A left-zero meter representation is displayed along with a numeric representation in the range of 0.00-29.00 inHg.
Gauge mode can be used to adjust idle speed with the tach function and mixture (carburetor) with the tach and/or gauge function. Gauge mode can also a be a powerful diagnostic tool.
In Gauge mode, if you use the yellow port, the tach is calibrated for 4-stroke motors, 1 cylinder/intake.
In Gauge mode if you use the red port, the tach is calibrated for 4-stroke motors, 2 cylinders/intake.
As in Balancer mode, for 2-strokes in Gauge mode you must divide the tach readings in half.
Features
Reliable, all electronic design, with digital signal processing and no moving parts.
Large, easy to read, LCD display.
Rugged housing with a clear polycarbonate top.
Vacuum hoses are removable with convenient, color coded, Luer type connectors.
Swivel-hook on top for hanging/attachment.
Simple one-button interface. Press/release button and wait for Auto-Zero calibration. The unit is now ready in balancer mode.
To access other modes and menu options, hold button pressed until desired function appears. Then release button.
The button is recessed to prevent inadvertent activation and breakage.
Auto Zero on power-up.
Auto Range.
Auto shutoff after 5 minutes of inactivity (except beacon and timed lantern modes).
Battery Voltage Indicator.
Automatic display backlight.
Bright White LED included for convenience.
Toggle LED on/off through menu or by a double press of the button for a quick flashlight function.
Rally/Tour/Camping LED modes.
Timed Lantern Mode illuminates the LED for 15 minutes then power-off. During timed lantern mode a single button press resets the timer to 15 minutes.
Beacon Mode flashes the LED in a randomly selected, 5-flash, repeating sequence. Potentially useful as an emergency flasher or locating beacon. (No, I'm not kidding).
Beacon mode does not time-out. It will persist until the mode is changed or the battery is depleted.
Specifications - I will be updating this info as the testing progresses.
Size TBA
Weight TBA
Storage temperature -30C to 80C (-22F to 176F)
Operating temperature -20C to 60C (-4F to 140F)
Vacuum Hose size/length 4mm (5/32) ID x 122cm (48 inches) SAE J1037 -40C to 125C (-40F to 257F)
Battery type 9V Alkaline battery (included) recommended
Typical current consumption and battery life (based on fresh Alkaline battery 500mA/hr 23C)
basic functions backlight off 11mA 45hrs
basic functions backlight on 16mA 31hrs
beacon mode (backlight on) 25mA 20hrs
LED on (backlight on) 34mA 15 hrs
Displayed Range (Resolution)
Balancer Vacuum +/-999mbar (1mbar)
Gauge Vacuum 0.00inHg - 29.00inHg (0.01inHg)
Tach 0-9990 RPM (<1500RPM 10 RPM steps, >1500RPM 50RPM steps))
Accuracy vacuum measurements TBA
Accuracy tachometer and internal timing +/- 0.5% @ 23C (+/- 2% over full operating temperature)
RoHS compliant
CE testing in progress
I've know Airhead owners run off and hide at the sight of technology, so introduce it to us slowly.
Do old airhead carbs produce enough suck to register on a dial? :rolleyes:
I never use gauges on an airhead, just use my ear(s). Only benefit is the gauges also have a rev counter next to the balance readout, so useful on those old GS's with no rev counter :thumb
Plus i'd just like to see if anyone can find any faults using the units.
