better horn
bisbee
VIGILUM
Newark Notts
anyone fitted a better horn than standard if so what and how please my 1150 had a magnum that was well loud but the horn on this 1200 2009 model is a bit of a damp squib:nenau
Stebel Nautilus seems to be popular. But they are MORE than LOUD
I don't know if people fit a relay with the 1200GS.
I had one on my ZZR600, and it really does sound like a train. The instructions do state "Do not use in a confined space, ie. a shed".
When I got mine, I thought PPPFFFTTT. It can't be THAT loud. So I stuck it direct to a battery. :blast :blast :blast
Yup. It's LOUD.
fitted a Stebel magnum instead of standard - better but not that great - have some Fiamms I want to fit but may try wiring the Stebel direct to battery first
I've got a nautillus on the cage and I did the garage trick.. pardon :D
only I'm a bit new to canbus and the nautillus drags over 20 amps irrc:nenau
:beerjug: Thats funny when I took mine in for the MOT my tester did the same and as for his mate under the car doing some work, well. The magnum is loud enough for me :D
stebel nautilus horn
I have fitted the compact nautilius following a guide on this site some where or may be it was r1200gs.info.
Used the horn wiring to drive a relay to the horn. (2008 r1200gs)
Am looking to wire up a switch spdt (single pole double throw) so that i can drive both horns. ( need to find one though)
Some times you need a quiet "bip" :angel and sometimes you need a "F.. OFF" loud horn :mad:
I
Is this on an '08 bike with ESA. Having removed the Stebel Nautilus Compact from my '07 GS, I find it won't fit in the same location on my '09 bike because of the ESA on the front shock.
As far as I'm aware - the Stebel Magnum can be wired directly to your existing supply, but the Nautilus requires a separate relay-fed supply (17A current).
Magnum will fit in minutes, Nautilus will take a bit of time
Al :thumb
I never use my horn :nenau
Cool, you must be one of those legendary riders who anticipate every problem far enough in advance that you can just gently adjust your speed or path, and serenely make your way past the scene of the potential accident.
I wish that I had that sort of ability, the foresight, the skill, the general awareness that meant that I never, ever had to honk at someone to stop them encroaching on my route. The patience to just serenely stop when a pedestrian stepped between the cars, coupled with the planning to make sure that the courier was no longer tailgating me, it is all very admirable.
A guy who is so i control of the world around him truly has his destiny in his own hands. With such ability, may I ask how you applied it in the work arena? I assume that you were comfortably a millionaire by the time you were thirty, have a string of charitable foundations, and are well on the way to curing cancer.
2008 without esa. The esa will block where i have mounted the horn. do a search for stebel nautilus on this site and achim. I followed his install.
As I mentioned needs a relay.
good luck
Sarcasm Sir does not become you :pullface
I repeat ... I never use my horn :pullface
By all means pap your horn ... loud or not, but never, please, still have the accident :eek:
If the horn works for you then fine, great, long may it be so :thumb
But never let it be your last line of defence :eek:
The person you pap at might be deaf, or listening to the 1812 at full volume with 'in hear stereo' :eek:
If you need the horn you need the brakes :D
Here we go again, sorry folks :blast
In London, I actually use it for freezing pedestrians mid stride. With the original horn, they'd hear the "parp" and just keep wandering right in front of me, meaning I had to stop. The twin magnums seem to hit a deeper part of their brain, a primitive part that says "I am about to be flattened, and have no idea what by". This lets me happily keep making progress.
Unfortunately, crossing this city, you either have to make your space, and force your right of way, or accept that it wil be a long, long journey every time.
I've got a Steibel on my 06 GSA wired as a direct replacement and whilst not as good as a pair it does the job. Car driver's think they've cut off a 38 tonne truck.
Lovely!
Are you running the pair of Magnums direct from the battery or will they run off the OEM Canbus feed used by the OEM horn?
I ran a single one from the canbus, but for the twins, decided that I ought to go via a relay direct from the battery.
I'm not certain what the draw is for them, but seem to remember that it was supposedly too much, and I definitely don't want to face tripping the electrics in a crisis wen what I wanted to do was let the world know that I was there.
