There is a method for checking the hall sensor, injectors, and ignition statically.
1. Remove the plugs and connect to HT leads and ground *the plugs.
2. Remove either one or both injectors and place in clear plastic bag.
3. Turn the ignition on and ensure the fuel pump primes.
4. Place bike in gear.
5. Make sure the side stand is up.
6. Rotate the rear wheel in the direction of travel, this will rotate engine.*
As the engine rotates the hall sensors will trigger the ignition and the injectors and you should see the plugs spark, followed by a spurt of fuel, followed by plugs spark etc. As the injectors fire, so does the fuel pump to pressurise the rail.
It moves everything in slow time, but you would see the same results quicker if you left it out of gear and cranked engine on starter.
Caution be careful fuel and ignition could cause fire.
This method Could be used to diagnose problems with one side and the other, like faulty injector, or plug lead, or plug. There are however other symptoms that give the same clues. Lumpy running, poor/no idle, wet plug , dry plug.
It does help with understanding how the motronic functions on the bike.
To be honest I doubt I would use this check other than to check the spray pattern of an injector, and I'm sure there are other ways to check them.
It's not easy turning it from the back wheel, and you need to get the engine to turn over at a pace other wise you might not see a spark. So you could leave it out of gear and turn the engine over from the nut on the crankshaft pulley.
The only thing that tells the motronic that the engine is rotating is the hall sensor, so if you get nothing, not even the pump priming as you rotate engine, then the likelihood is the hall sensor are stuffed.
That's the long method. A quick check would be to
pull the plugs.
Ignition on,
check for pump prime,
bike in gear,
turn back wheel, and listen for the pump priming as you rotate.
No pump prime during rotation.
Failed hall sensor.
I'm hoping I got this right,if not anyone feel free to jump in.
