Hi all
I just wanted to run a couple of things by you before I buy the part I think it might need. There are two issues, the first, minor, is that I can’t start the bike in gear clutch in with side stand up. I’m not really bothered by this but apparently I should be able to. I need to check the cable by the clutch. But I don’t know if this would also affect the main issue below.
For a few months I’ve noticed it’s slightly more tricky to get it into neutral. Not get it in mechanically because it goes from first to no gear, but for the bike to know it’s there. Normally with a bit of a wiggle of the gear shifter it recognises it and all is fine.
However, it’s been stood (stored outdoors, and it’s rained recently) for about ten days. Went to start it today, key in and the dash lit up as usual (horn worked headlight and main beam works, part of my checks) but it wasn’t showing it was in neutral. I had no problem getting it into neutral when I last rode it and it showed on the dash. So I spent a few hours reading and fiddling, I removed the gear potentiometer and cleaned it with electrical contact cleaner (but tbh I don’t know what I’m cleaning, I just wiped away anything and sprayed it on, then put wd40 on it and put it back together. I also disconnected the electrical connector (further anlong the same wire) and sprayed that with electrical contact cleaner before putting back together (no wd40 here). Still the same issue. It goes into first gear fine. This morning I could get it briefly to show neutral but when I started it, it didn’t maintain this, and I could cycle the gears all the way to sixth, but this evening it does first or blank and now doesn’t sound like it’s engaging the higher gears. (It’s on the centre stand now though, wasn’t this morning, not sure if that makes a difference re:load etc).
ChatGPT said I should check the voltage at the electrical connector which I will, but is this the right area to be looking in? If I’ve cleaned it and it still doesn’t work, is there anything else I can do before buying a replacement?
Thanks in advance.
Thanks in advance.
