2014 GSA LC - cut-out switch in neutral
Andy B
Lea & Perrins country
I've always parked up in gear and then just pulled in the clutch to start the motor (side stand up of course). It;s decided to stop working - I now have to select neutral to turn the motor over. Is it a regular problem and an easy fix?
I took mine out and put a bit more bend in the actuator arm, seems to have done the job, if it goes again I will get a new switch
