side stand cut out switch
Green Boy
hampshire
Here's a curious one on a well maintained 2004 1150 gsa...
...the bike starts fine in neutral from cold with the side stand down but most of the time if I then kick the side stand up it will cut the engine even in neutral.
However if I do the same thing when the bike has warmed up a bit, it doesn't happen and operates as intended.
I appreciate this is not really a problem in the grand scheme of things but just interested if this has happened to anyone else and what they did to fix it.
Ta
Sidestand switches are well known for causing bother, either by-pass it or replace it :thumb
