Bike Won't Start??
for £196 its worth it just in case i have a fd go down or clutch etc then you get your money back ten fold , it everyones choice isnt it the debate could go on forever , some for it , some against i just use it for piece of mind and get it as cheap as i can :thumb2
Don't count on it covering your clutch unless it has a manufacturing defect or is due to a failed oil seal etc. Dealers consider them a wear item and at £900 to replace you had better pray they find a fault and it is chargeable under the warranty terms.
I cant imagine any warranty would cover wear and tear, and id check myself first with a clutch problem so i dont get a heafty bill , under normal use they dont go that often so its usually caused be a secondary problem , which would then be covered so hopefully redeem any money paid into a warranty
