bleeding question
cookie
Stay Frosty
Failed State
changed all the hydraulic fluids in my 1150 today. first time i've done it on an ABS bike, done loads of others, cars, etc.
i used one of these cheapo, valved tubes & it was generally a piece of piss after i'd swapped the special BMW bleed valve on the O/S/F caliper for a normal one.
moving on to the point of this post.....
when it came to doing the clutch, i screwed another bleed nipple into the BMW one. this worked but was very messy.
can the odd BMW bit on the end just be swapped with a normal bleed nipple? i was tempted to try but was unsure if nipple would seat properly in the hose fitting.
ps. i then went on to change fluid in my le mans linked system, a job i've done many times before. as usual it would not get rid of air using the normal methods. i had to resort to using the EasyBleed pressure system.
much more trouble than the BMW. i thought it would be the other way round :rolleyes:
bump
can't believe nobody knows this :confused:
cookie said:
bump
sorry, i'd missed this thread - Yes .
i take the small grub screw out of the block, and insert a normal bleed nipple to bleed the clutch.
I got rid of the one on the front-right caliper and replaced it with a normal bleed nipple, I think you can do the same with the clutch...
motomartin said:
well thats a job 'WE' don't have to think about, along with slave seals .... :D
where do you stand on the hard part or spare gearbox issue? :D
thanks for the info all.
