Bleeding rear brake, from pedal to servo
ELIMINATOR
Hampshire.
About to replace the metal brake pipe that goes from the brake pedal to the servo, not sure which nipple is meant to be used to bleed the system, any ideas?
For abs/servo: looking down on unit from rear there are 6 bleed nipples. Two on left , four on right. First bleed rear left, then 2nd from front on right followed by 4th on right (one nearest back) then redo first one (rear left). Useful to have open and ring spanners.
Probably worth renewing fluid in servo to brake calliper whilst your at it.
Thanks for the replies.......... Jesus, just tried threading the brake pipe from under the battery box to its mating thread................ No idea how it's meant to be done!:mad:
Yeah, I had a bugger of a job with mine..taking it out & trying not to get brake fluid splashed around after ditching the servo completely :D. Definitely involved some bending.
