Bleeding the EVO brakes on an early-model R1200GS.
Nick V
De Rust, South Africa
I recently got wiped off my '06 GS. The bike went down on it's right-hand side and among other things, the front brake fluid reservoir was smashed. By the time I got the bike back up, the front brakes were spongy to say the least.
I decided to flush and bleed the entire system while I was in there. I didn't know how, but my watchword has always been 'How hard can it be?'
A quick chat with a mate who's a techy at a BMW Motorrad dealer and 30 minutes' worth of digging on the internet yielded enough info to know what everything was, and how to proceed.
For anyone else interested in this job: don't be put off by the hype. It's not staggeringly difficult - just a bit tricky in places. If you have a reasonable amount of previous experience in bleeding brake systems, you'll have no problems.
The important points to remember are:
  1. The job is done in four parts: front wheel circuits, rear wheel circuit, front control circuit, rear control circuit. You can't just do the traditional 'front-brakes-'n-rear-brake' like you're normally used to.
  2. The fluid reservoirs for the wheel circuits live on the ABS regulator, under the fuel tank. You'll recognize them straight away - the fluid caps are removed using an 8mm Allen key.
  3. It is possible to fill these reservoirs using a syringe, but I don't recommend it. I built a fluid filler tool by gluing a soft tapered plastic plug to the end of a cheap plastic funnel.
  4. Keep a syringe handy for adjusting fluid levels. The bigger the syringe, the better, although a 10cc one will work fine in a pinch.
  5. Wheel circuits:
  • Unscrew the Allen-head reservoir cap. The front is marked 'V' (Vorderrad, or 'Front wheel'), the rear 'H' (Hinterrad, or 'Rear wheel').
  • Insert funnel, and make sure it's well-seated.
  • Fill funnel about halfway with fresh DOT 4.
  • Turn on the ignition.
  • Press the brake lever, opening the bleed nipple at the same time. Flush until the fluid is clean and clear.
  • Close the bleed nipple, letting go the brake lever at the same time.
  • Bleed the wheel circuits in the following order: front left, front right (both through reservoir 'V'), rear (through reservoir 'H').
  1. Control circuits:
  • No need to turn on the ignition for this round.
  • Unscrew the handlebar (front) or under right butt cheek (rear) reservoir cap as appropriate.
  • Draw off all old fluid in the reservoir and dispose of it. Refill the reservoir with fresh DOT 4.
  • Locate the six bleed nipples on the ABS regulator. The order these must be bled in is not intuitive - if you're looking at the regulator from the left-hand side of the bike, with the fluid reservoir caps closest to you and the nipples in a horizontal line, mentally numbering the nipples from one to six, the bleed sequence should be as follows: 1, 2, 4, 1 (re-filling with fluid through the handlebar reservoir), then 6, 5, 3, 6 (re-filling with fluid through the under-butt reservoir).
  • Press the brake lever, opening the relevant bleed nipple at the same time. Flush until the fluid is clean and clear.
Congratulations! :aidan You have just tackled what is possibly the world's most needlessly over-complicated braking system.
Hello Nicky V
I am also in JHB "EASTWOOD" as apposed to the "WildWest"
got any pics- want to do my brakes as well. can you perhaps show me what sort of funnel you made up?
thanks for the write up
Hello Nicky V
Aha! A fellow inmate of the People's Republic of Zumaville... :thumb
I can't post pics as I'm not a subscriber, but I'm a technical writer by trade, and I'm busy doing a detailed write-up of the whole procedure.
Not sure when I'll be done... I may need to do a dummy re-run of the whole procedure to get the right pics! :eek:
For the funnel, though, it should be very easy. A cheap plastic funnel from the kitchen section of your local Shoprite should do the trick, as long as it has a narrow end of roughly 10mm and can hold at least 100 ml. (When a bleed nipple is fully open, the servo is active, and pressure on the brake lever is high, the system shifts fluid very fast.)
For sealing against the reservoir threads, I used an old plastic electrical grommet which I think came off an Opel Astra at some stage.
I roughened the narrow end of the funnel using 100-grit, cleaned everything with dishwashing liquid, then mated the two parts using cyanoacrylate superglue and left it to cure.
What part of the East Rand are you on? Since I'm not going to have a detailed write-up done for a while, it might be worthwhile dropping by and showing you the way around the regulator. :)
that would be great - Im in the Kempton schmenton park dark
i would like to come over and meet you and perhaps help with the write up?
If you can control your saliva and read without moving your lips you don't need a funnel.
Just pour the fluid in from a beaker while you operate the brakes with the ignition turned on, and keep the level up. :D
Thanks for the suggestion! :D In an ideal world, it would be a way to eliminate one more piece of superfluous equipment.
But personally, I prefer the assurance of being able to keep a beady eye on the fluid level as it falls at a more controlled rate. To each their own... ;)
There's not much more meat you can trim off the procedure before it's down to the bone...
Hi again K,
I see I don't have an option available to PM you... feel free to drop me a mail at [email protected].
We can meet up on one of the coming weekends, yes?... :)
Comprehensive How-to available.
Hi again, peoples... :aidan
I've finally written up and illustrated a comprehensive 'How-to' guide on the EVO brake-bleeding procedure.
It's available in *.PDF to anyone who wants a copy.
Since I'm not a subscriber, I hope one of the mods is reading this - I'd like to offer this doc as an addition to the 'Useful Guides and How Tos' section of this forum.
I have no hosting facilities, so please feel free to PM me and I'll mail the doc through (it's only 348 KB).
The guide doesn't just include brake bleed instructions; it also has a section on important peripheral tasks such as setting the brake micro-switches and performing the brake pressure-hold test.
Gratis copies for anyone who's performed this procedure, and would like to read the doc with intent to give feedback and potential suggestions for edits. ;)
Any volunteers? :pullface
How to guide available?
Hi Nick,
Do you have copies of this guide available? I'm planning on bleeding the brakes on my '04 GS this weekend and would appreciate reading up on it a bit more,
Many thanks,
Kieran.
