Bluetooth issue
stick
Lord Lytteltons Door Mat
Can anyone give any advice to the following.
Fitted a new starcom digital unit , connected to my 660 (cable connection) , now when i connect the phone via blue tooth it connects fine and i can make calls and can hear the other person but they cannot hear me at all --- any ideas ? :comfort
Hi Stick,
I am assuming that you are using the starcom cable CAB-66, you need to make sure that you have plugged the cable into the correct socket, I think it has to be plugged into the Phone 1 socket.
I had the same problem with my 550 and rang starcom and that sorted it out.
Hope this helps
Bigrodders :thumb2
Jackpot
Hi Stick,
Hope this helps
Bigrodders :thumb2
Bigrodders - you have hit the nail on the head - that is the solution as i have just finished speaking to Starcom and they said the same.
I thought at one point i had the wrong phone , but as you say the phone 1 port is the only port with audio out on and i had ( following the instructions) put it in the GPS port , which you would have thought would make sense.
Thanks for your reply.
Stick :beerjug: :JB
