moonhead911
any one no the oring size iv google it with no luck
thanks
thanks
Im pretty sure you'l find its 5x1.5. If you look at the info from JVB's site he also gives you the adjustment screw part number which tallys up with the part number on the OEM site -
item 14 Adjusting screw M 9X0,75 2 Part number 13541342074
http://www.jvbproductions.com/BMW_Alternative_Parts_List.html
Hi
I ordered 2 5x1.5 mm o rings from Simply Bearings and they are not the same as on my 2000 GS1150. I measured the o rings from SB and they are as described so not them. HTH
A whopping 66 pence from motoworks?
https://motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=30&Ct=FA&SbCt=BA_15_30_FA_70&spPage=2
Plus £3.30 postnearly ordered the wee clip on the rear brake caliper pad pin till I saw the postage cost for a 50p clip.
Hi
