BMW SAT NAV MOUNT...
I use a Cardo BT intercom just for when I have my wife on board. Will I be able to connect both sets to the Nav so that we can both hear the directions?
I could make calls on the move but in practice it's a bad idea. I enjoy the music but that's as much distraction as I will tolerate. I can see calls/texts etc and will stop and call back. The iPhone has a really easy way to change your voicemail greeting without too much bother so I can switch my greeting to say I'm on the bike, I've seen you've called and I will call back when I can.
I rarely text while riding the bike, even with predictive text it's quite hard typing while riding along. Cruise control helps with freeing up more digits....
Sent from my iPad using Tapatalk HD
Just say tell Siri "Read last message" and afterwards you can dictate your reply.
I use a cardo G4 paired to my iPhone. The "phone" button on the headset connects me directly to Siri for voice dialling, selecting playlists, etc. Works a treat!
I use sure earphones for same reasons and got a 660 not a bmw unit again due to bmw unit not having the port for headphones.
However I actualy use bluetooh as I can connect to phone (iphone and GPS unit), I use a jabra unit which looks like a dog tag, headphones plug into that and it connects by bluetooth to the iphone and the gps unit, the jabra set has a mic and as it sits under my jacket by my throat it picks up voice without much road noise (not brilliant but ok) I can then listen to gps/music from iphone/music from gps etc etc etc. I get about 8 hrs use out of mine and it charges over mini usb.
For me its the ideal solution.
I use high end earphones (Shure E5) and have everything sorted without any cables in the way.
If you want it all working then the way to do it is this:
Get a bluetooth decent connector first, I use a Sony Ericsson MW600, it also gives me a radio that way. It can handle multiple connections as well.
My iPhone connects to the NAV IV and is paired to that.
The MW600 connects to the NAV IV as well.
The MW600 has a second connection to the iPhone just in case I want to listen to music from the iPhone. I have an SD card in the NAV IV with music on it.
Any phone functions, the NAV IV prioritises and plays over the MW600 with my nice Shures, same for music, speed cameras and satnav.
If I want radio, the MW600 gives me that and the NAV IV still interrupts.
I have two music sources this way, the card or the iPhone.
All works and no cables as I use the very short primary cables on the Shures straight into the MW600 and that clips at neck level. Ay phone functions show up on the NAV IV.
Count
I bought myself a MW600 and it connects to the Nav IV to receive navigation instructions, and to my iPhone for music and phone.
However, when I try to use it to listen to music playing on the Media Player on the Nav IV, I get an error message telling me to "Connect headphones or an A2DP Bluetooth headset".
Do you use your MW600 to listen to music from the SD card on the Nav IV? And, if so, is there a trick to getting it to work together.
I am puzzled, as the MW600 connects via Bluetooth for the navigation instructions, but NOT the Media Player!!!
Bluetooth Phone to GPS. Bluetooth GPS to autocom (using their bluetooth dongle Part 1273 which turns the bluetooth into a 3.5 jack). Connect Part 1188 to 7 pin connector and plug ear monitors and microphone headset into it. (the cheaper alternative for the last part is to cut the headphones form your helmet headset and wire a 3.5 stereo jack to it - at your own risk of course... but it worked for me when I used them)
:thumb2
Always powered, rider to passenger intercom, music, phone on the move etc etc
Count
Sorry to bring up an old thread - but am looking to find a bluetooth receiver like the MW600 that will pair up with the Nav IV located on a Garmin cradle.
Some seem to say the Sony does work, others not.
Does it make any difference if this is on a Zumo 660 or BMW cradle?
I have a BMW nav IV on the LC cradle. And yes, the Sony MW600 will pair with the NavIV so that you can hear directions and music etc.
Only bugbear is that the screen on the MW600 is all but unreadable in any sort of sunlight, which makes it a bit hit and miss when switching between music from the Nav IV or the FM radio on the MW600.
Pauls set up sounds very elegant, is there a decent company or just a clever a bloke who can supply and sort out the whole system if you are 'analogue-man' (me)? :blast
Thank you for a very helpful message. I'm not good with technology so please bear with me.
I've got a new GS TE with the bracket for the BMW Satnav all fitted (but no Satnav). I also have an iPhone 5 with TomTom app which works well but only visually as I have no blue tooth helmet microphones etc. Ideally I would like some sort of device that enables me to:
Listen to SatNav instructions
Listen to music on the iPhone
Receive and make phone calls.
I am not bothered about helmet to helmet communication.
Your suggestion of the MW 600 would seem to deal with the first two points but not the phone call problem.
Before I get jumped on for making calls for riding it is actually more for talking when stopped without having to take the helmet off. I have looked into the BMW communication system but it is quantum leap in cost to buy their SatNav and bluetooth communication system when I already have a perfectly good SatNav on the phone.
The Sena SMH 10 looks like a good option but seems pricey compared to the MW 600 for just having a mic.
Any ideas? Thanks
two for the price of one?
Hopefully this may help a couple of questions,,
I have the MW600 set up.. firstly paul08.. the message about not connected I had with mine, .. steps to check before doing s full reset,,(which worked are ).. connect MW600 as audio not phone, connect it first to the NAV, then connect phone, and to stop that message appearing once paired turn on the MW600 before starting up bike ( turning on Nav)
and to answer last post,, I don't make calls but Yes you can easily access mic on MW600 at side of road and return / make call..
hope it helps a bit..
cheers :thumb2
cheers :thumb2
OK so the MW600 has a mic? In which case it does all I need?
cheers :thumb2
So why does the Sena SMH 10 cost £184 and the MW600 cost £25?
The MW600 doesn't have a mike! Just works as an FM radio, or as a means of getting the nav directions or music from your NAvIV to your ears.
The Nav IV will tell you that a call has arrived, but you will need to stop and use the phone to ring them back
http://www.androidcentral.com/sony-ericson-mw600-hi-fi-wireless-headset-review
I am now totally confused. the attached link which is a review of the MW600 states "Call quality
The microphone for the Sony Ericson MW600 is located on the end of the front of the unit – near where the earphones plug in. For the most part, call quality was good. Users could hear me as long as my mouth was not too far away from the microphone.
Because the microphone is on an external unit that can be clipped onto your clothes, you need to be smart if you want to use this for phone calls and put it at least nearby to your mouth."
So help me here - does it have a mic or not and if it does what is the reason for the massive price differential between the MW600 and the Sena SMH10?
I must have a look. Watch this space
However, I am not sure how you would get the MW600 inside your helmet so that you can use the inbuilt microphone (if there is one there)
to clarify ...
MW600 HAS a Mic its located at the front and is near the 3mm jack enters..
below is the answer button..
just plug in your own ear buds, (though it does come supplied with a set, place unit dongle inside jacket,, but a tip.. don't bury it too deep,, just in side a flap on a zip or inside pocket etc
as I said, best used when stopped, The NAV will show you when someone has called.. or you will hear it.
you can walk away from bike it will disconnect itself but when you start the bike and sat nav it connects itself..simples,,,
just used it for a 1400 mile 4 day trip to Germany and it was great,,
I have a Scala G4 on another helmet which is good but I don't like the Ugly attachment and I cant use it on another helmet..
can attach pictures if it helps?
:thumb2
to clarify ...
:thumb2
Many thanks to everyone for your help. I am only planning to use it with the iPhone at this stage as don't see the need to fork out £600 for the BMW unit when my TomTom app works just as well. I had a vision that I could attach a self adhesive velcro strip and stick in the mouthpiece of my Schuberth SR1 if it fits.
Still don't understand the massive variance in price between the MW600 and The Sena SMH10.
Sena SMH5 is what I use, works great with iphone for music (I never make or take calls but it will do it ), talks to my zumo 550 and can chat to the boss when she`s on pillion. :thumb
Cheaper then the smh10 , not as bulky although looses a few of the features of the 10 but depends on what your after, battery life v.good too. Highly recommended imo.
Thanks. What is the difference between the 5 and the 10? what is teh main feature that the 5 loses from the 10?
