Deleted account 200417001
If nothing done to ecu nothing to be seen correct
Correct, so Hilltop should be fine!!1
Using their super duper raspberry pi and hidden 'map'. They will have no bother
Yes, you can’t trigger any of the warning signs to Bmw unless you actually write to the ecu.
Correct, so Hilltop should be fine!!1![]()
Thank you, yes exactly , nothing can be hide in BMW ecu, every time you look ecu has log file, and send to BMW when fix firmware
Hill top hide their mapWhat is hidden, no can hide in BMW
Hill top hide their mapIts in a hidden part of the ECU
Sorry not possible, not possible hide in Bosch ECU
It’s never possible to hide anything in a micro-controller system that is accessible from outside, there is always a way of detecting changes - the only way to hide anything is to not actually make any changes!
yes sir you are correct
