For Sale BMW Winter tyres.
GedJack
Lancashire, God's country !!!
These came off my 2018 530 D X drive Touring.
The fronts have been in for two winters. The rear for 1 winter.
Fronts are Falken run flats, 245,40,19. both with approximately 6mm tread on them.
Rears are Verdestien, 275,35,19. These have approximately 8mm tread on them.
For me they transform winter driving.
£400 collected please.
I’m 5mins from Charnock Richard services on the M6.
For anyone in the UK who MUST drive when it's icy/snowy out there... winter tyres (or all season ?) are an absolute must ! Especially for rear wheel drive cars. It's not so much for your benefit, but for all the 'sensible' drivers behind you, when you block the road !
just sayin'....
just sayin'....
As mentioned previously, these are NOT just for snow/ice... They're for when it's cold & wet. Essentially from anytime now, through to April.
Below 7 degrees, normal tyres lose their stickyness and the rubber starts to harden. Winter tyres have a higher silica content in the rubber, to prevent this. The tread pattern is usually better for water dispersal.
HTH
M
just sayin'....
We've had winter tyres (on a spare set of wheels) for many years. 40 yrs ago I'd have gone out to play when it snowed...now it is both for better traction for several months but also a case of 'if we get caught out by the weather, we can get the car somewhere safe/home...out of the way of the summer tyred morons or the pointy corner of a snowplough.
What is the PCD, ET & centre bore size?
PCD & ET, sorry you’ll have to explain those abbreviations?
ET is the offset (usually a marker on the wheel with 2 numbers after)
PCD is the bolt pattern; eg 5 x 120 (it should also be on the back of the wheel, too)
I think he’s selling tyres, not wheels… :blast
