BMW ZUMO 550
  • Thread starter Thread starter malcomius
malcomius
I want to wire the unit to the bike rather than relying on the unit's own battery. It came with a nice long power lead which has a white plastic plug (female) on the end which looks like it should attach somewhere conveniently but i've no idea where. Any help on this please?
But ...
.. if you'd like to swap it for a non-canbus lead then pm me :cool:
Hi, thanks for the reply. Photo attached.
If you have a 1200GS then that cable will plug directly into the canbus wiring loom. The connector on my 06 1200GS is positioned by the headstock. The connector is taped up so you will need to look for it. For 08 GS I think the position of the connector is slightly different.
Do a search on the GS site as Im sure there are pictures showing the connector location on the bike.
If you have older 1150 or 1100 GS then this connector will not be much use as the bike doesn't have one.
Hope this helps
Ian
Thanks Ian, mine is an '07 1200 and you're spot on. Much appreciated.
