Bryn Well-known member Moderator Moderator Joined Sep 20, 2003 Messages 14,084 Reaction score 529 Location South Leicestershire Jul 31, 2015 #1 Can anyone confirm the size of the 4 nutsthat secure the zumo 660 or 590 cradle to whatever mount you're using? I understend from a pdf that they are M4 x 40 mm panhead The head size of the nylock nuts is needed as per the diagram..thanks Attachments image.jpg 58.9 KB · Views: 54
bisbee VIGILUM UKGSer Subscriber Joined Jun 10, 2007 Messages 12,086 Reaction score 11 Location Newark Notts Jul 31, 2015 #2 Mine are(but non nylock*) 7 mm across flats and 7.75 mm across corners hth
Bryn Well-known member Moderator Moderator Joined Sep 20, 2003 Messages 14,084 Reaction score 529 Location South Leicestershire Jul 31, 2015 #3 bisbee said: Mine are(but non nylock*) 7 mm across flats and 7.75 mm across corners hth Click to expand... Thanks for that...
