Stig Of The Dump said:Why not use stainless spokes? Im just about to rebuild a couple of wheels with excel rims talon hub on the front and have made a rear hub 650GS had assumed stainless would be the wat for spokes but am willing to be educated.![]()
Stainless can be used for spokes and looks good doesn't rust etc. It does not have the same tensile strength as an alloyed steel grade, although its pretty close. Stainless grades can and do work harden (become brittle) when worked and a stainless spoke is more likely to fail under hard repeated use. For the 650 its ok to use, on heavier machines doing off road or two up loaded work I personally wouldnt use them. For the cost differential (pennies when bought in bulk) BMW would fit stainless if it met the required parameters. Some out there will say I've had them for years etc, all my bolts are stainless and I've had no problems... I express a purely engineering view, stainless steels (A2) does not have the correct properties for automotive critical use and should not be used for anything other than cosmetic application.
