Bolt sizes
Cheers allan, just in the process of getting the bar to send to you,if you are happy using your bolts I wil recompense when i see you,
ta, BD
Migsel ships the bars with the correct size bolts so you shouldn't need to buy any.
Rob,
BD has bought it second-hand from off the site minus said bolts, it would now seem!
Personally I would have asked for a refund........;)
I know that they are M6, but can you confirm the length, pretty sure its around the 40mm mark?
BTBR
The bolts are 50mm long and the thread is 25mm of that length.
Make sure that the bolts are not overtightened because they thread into the oil cooler and overtightening can pull out the captive nut.
