FastFred
No not Susan Boyle....
Went for a ride this morning and set tyres to just over 2.2 front 2.5 rear for solo riding. Temperature was about 5 degrees C probably. After riding ten miles I checked the tyre pressure monitor and it showed 2.4F and 2.8Rear (bar). Obviously this is because the reference temp is 20deg C. Does anyone know what typical volumes are in the front and rear tyres I can calculate what the onbike computer should be over-reading when the temp is colder than 20deg C? Guess I should read it as soon as I set off and just note the difference is the answer.
Does anyone use this tyre check function regular?
