Brake disc spring washers
scud
Camberley, England
2002 ABS 1150 GS
I replaced all 10 bobbins and spring washers a few week ago with new ones, in an attempt to stop the disc "rattling". In fact, I even put new discs on. It reduced, but certainly didn't stop the movement.
Today, I found that 8 of the new spring washers have broken and disappeared! I have probably only done 100 miles!
What would be the cause of this?
I did find that my some of my caliper pistons were a bit stiff, now they're all ok.
:nenau
The rattle is caused by wear on the disc mounting bosses on the wheel. You need to file the bosses flat, as described in this thread;
http://www.ukgser.com/forums/showthread.php?t=96118&page=2&highlight=rattle
FANTASTIC!!!!! many thanks!!!
I have filed them down... I honestly thought they WERE locating lugs on the wheel.
All sideways movement now stopped....
FYI though, I have had to shim out the brake caliper with a small washer, to ensure that the brake disc does not rub on the caliper.
