I've fitted a new set of disks and pads to my 1150GS. I've still got a bit of pulsing on the lever which I assume is the spring washers?
Secondly, the disks themselves actually move a little on their mounts. This isn't movement because of the spring washers, it's in the other direction (the same way the wheel moves). Is this going to be worn bobbins to replace as well?
I've read all the threads about this but they seem to refer to lateral movement caused by wear on the hub more than anything else.
...probably needs a bit more faffing about adjusting the bolts.
