JimmyUK
(also on Advrider. Don't read it twice)
Hi all.
I unfortunately did the last 100 miles of my 2800 mile European trip in the comfort of a breakdown recovery van. In short, I was riding along the motorway, felt a split second jolt as the bike (2005 1200GS) decelerated momentarily and found the brake failure light, and triangle flashing ( once a second, so ABS according to the manual). As it was getting dark, raining a little and I had breakdown cover, I decided to play it safe and get her carried home.
As I'm waiting til saturday to take it into my dealer, I decided to check things out. I would really appreciate someone confirming this for me.
When you apply the brakes, you hear the servos sound, and they wine more when you press them harder until, it reaches a level which stays the same, despite any additional effort. This I believe is right, yes???
At the moment, when I apply the back brake (front is fine), the servo sounds up until a point where it seems to shut off (no noise). I don't recall the two brakes being different before the problem. It isn't on my father's 02 1150rt anyway. Also, I found the back brake to be very inaffective (more than usual ).
It would be great if some of you could have a quick check. My initial thoughts are dodgy, but not completely failed servo or ABS sensor playing up. Thanks in advance, James.
Hi all.
