If not it May be fluid levels or a dodgey rear lamp assembly You should have a flash code sticker under the saddle to tell you what the failure is if the lights are flashing a code
If you can get the OBD fault codes read, you would have a much better idea of what is causing the fault lamp. If the red triangle isn't lit up I would guess that it's not a serious problem, could be as simple as low fluid in the internal reservoirs.
