chrismckay
Hello Guys,
I have just taken my RT 1200 out for its first run of the year. Prior to winter hibernation, I had the dealership change the brake fluid, I'm 200 miles from home and have noticed the front brake fluid reservoir is weeping, nothing major but it is passing the seal enough to notice it.
The fluid level is at the very top of the mark, perhaps even a little over, and the gasket/rubber boot seems a little misshapen, in that it seems to be bowing in the centre whilst you look through the front of the reservoir, the screws are all tight.
Any ideas guys from the above information? Can you purchase a separate gasket if needed?
Chris ☺
Chris ☺
