Brake hoses for R1150gs NON-ABS
(RIP) willstatt
Lost
derbys
I'm slowly gathering the bits to remove the abs from my 1150. I've ordered some s/s brake lines from Goodridge, but I think they're the wrong ones? I ordered the non-abs ones as is what it's 'going' to be, but the bend on the caliper end is at about 90 degrees whereas the existing ones (factory originals) the bend (near the banjo) is about 45 degrees.
Is this because the non abs calipers are different or something, or have goodridge made the pipes wrong do you think? (My calipers are Brembo.
If anyone has a 2001 or thereabouts non-abs 1150, would they mind having a look and letting me know please.
thanks
Will
Quick Check
Hi Will,
2001 1150GS non-ABS with Brembo calipers. The bend near the banjo is 45deg - or maybe even closer to 30deg?
Cheers.....................Grizzly:thumb
