R1100GS non ABS Rear brake hose
MarkShelley
Very similar to Paolo Maldini
Norfolk, England
I am working away at St Andrews and the rear brake hose on my non ABS R1100GS failed today. It looks like where the hose joing the banjo at the caliper.
I called John Clark Motorrad in Dundee this morning as I have very limited tools with me and I was going to book it in with them if they could squeeze me in quickly. I was told the service guy was busy but would call me back. As I was out and about on site working I said I would email him, which I did. I had heard nothing by 1.30 so I called again and was told his computer was down. I asked to speak to him, but he was busy again and would call me. At about 4pm I lost patience and called their spares department so at least I would know whether they actually had the part in stock. They didn`t so I knew I was not looking at a next day `we will squeeze you in` scenario. I knew this was unlikely anyway as I had to wait nearly 2 weeks for them to be able to fit a pair of tyres a week or two back after Cupar motorcycles decided that they were unable to fit tyres to my bike because of the spoke pattern despite taking a deposit for the tyres and having to wait a week for them! Fearing that John Clark would not call me back today I called Moto Bins and ordered a new hose for first class delivery to me up here so I am going to do it myself. Incidently John Clark finally called me back at about 4.45.
It looks to be a case of just unbolting the old and bolting on the new and bleeding. I have ordered the washers by the way. Is there anything I need to look out for particularly?
Should just be a bolt off/bolt on and bleed. Rear brakes are usually pretty easy to bleed. To be honest, I think if you have mechanical abilities this generation of brakes is best done by the owner.
If you are travelling about then folk like National Tyres are usually pretty OK if you are fine doing the wheel removal/replacement.
Re parts: I worked for a dealer for a while and used to use M/works or Bins for parts... usually with a better discount:augie
PS 11mm spanner for banjo as I remember.
Thanks for the 11mm heads up. Pretty sure I have not got one in my tool tube so will get one when I pop out to get the fluid. Why do these things always happen when you are really busy!
Check the 11mm bit:augie I seem to remember that as the time for my "adjusted" 10mm spanner but I haven't double checked! Also you will have the inline fitting at the master cyl.
Mark, I am being a total w:augie:augieer and not checking so here goes. I have just been out and measured my GS. The banjo and the inline fitting are 14mm, the funny little bleed nipple is 8mm. The hard line hex is 11mm. It looks a simple job and as you have no ABS then things are even easier.
Sorry about the mis-info!
Watch the inset bleed nipple for breaking. If it does you can buy both bits from M/works or similar. You can bleed via the banjo bolt as a last resort.
If yours goes to a hard brake line fitting then you will need a 14 and 11 to stop it twisting.
Off for a coffee:blast
Mark, have you read Steptoes sticky on brake hoses? Also, if your front brake hoses are as old as your rear one that has failed, I would reccomend that you change them asap.
I have read the sticky. I will do the fronts when I get back home in a couple of weeks.
Part arrived from Moto Bins today and was fitted in 20 minutes.
Jobs a good un!:thumb2
