nedflanders
Well after the bike reached 13k miles the front brakes developed a judder exactly like the disc's were warped. Decided to have a go at cleaning the disc's before I forked out a fortune for new ones. First off I took out the front pads and got some extremely fine wet and dry, using this damp I gave the discs a light rub down and then a clean with spray on brake cleaner. I then used coarse paper on a flat surface and gave the pads a good rub down and again cleaned them with the brake cleaner. After putting everything back together I took it for a test ride and found the judder had completely gone, been out today again bedding the brakes back in with gentle braking and the judder is still gone, even with a couple of hard braking applications from 70-80mph. Total time took about 30mins, might be worth anyone experiencing the same to try it before shelling out for new discs
