Brakes
Anthony Byrne
Dublin Ireland
Hi folks,
I changed the brake lever on the bike F800 gs 2016 and wanted to know is there any way to make the the brake light more sensitive, I believe it’s pressure activated as I couldn’t see a switch anywhere
With all ABS bikes, the front is pressure sensing, via the ABS module, the rear is switched electrically. Seems strange I know, but saves wiring up the hand lever I guess.
I don't know whether there is any adjustment that your dealer can make?
I've heard it said that a brake fluid change, including cycling the ABS pump improves sensitivity, but please don't take that as gospel - maybe talk to your dealer/local marque specialist.
