Brass screws on throttle bodies.
Robh1664
Dartmoor, Devon.
Hi all
I've just refitted my throttle bodies following a Dan Cater rebuild (he da man). Does anyone know what a good start point for the brass screws is...... i.e 1.5 turns out from fully in. TPS has been set, bike fires up fine, just need to set up the ballance.
Cheers.Rob.
2 turns out from lightly seated is where I start.
Cheers Nin.
Oh, don't forget your passport for Kernow. The are a funny lot down there. Great rebuild by the way !
Start with the idle screws wherever you want - 4 turns out will give you a faster idle, if you want to start with a slower idle start at 2 turns out 😄
