I have a 1995 1100, 81k on the clock. I have had to replace my throttle cables as they started to fray and cause the throttle to stick.
Dismantling was straight forward. However I can not make the clips that hold the cable nipples in place on the throttle bodies do there job. The clips have a part that is circular and goes around the baffle shaft and the spring that returns the baffle closed. The clips just floats around and offer no tension to hold the right angle clip part over the cable nipple. The latter just falls out, particularly the right hand side at the end of the link cable. What am I doing wrong?
