Brembo red front pads.
Pale Rider
Loughborough
Does anyone know the thickness of the friction material on a set of new Brembo red front pads? Im down to 3-3.5mm and just trying to work out how much longer they will last.
Thanks.
Thanks.
Either 8 or 9 mm depending on which pads you have. Have a look on Btembo’s online site.
MOT man will usually moan when down to your last 1.5mm - for most users that'll see another 20k miles. for lively ones that's 5k
if brave enough you go till the lip of the disc grinds on the pad backing - then you know its time to get the spanners out
As per Botus above.
1mm is the spec limit. Yours should last ages, depending on how/where you're riding )town riding will use them more quickly)
Sent from my SM-S908B using Tapatalk
