Sancho Panza
My HID dip light failed the other day, I think it was the ballast unit as the bulb looked Ok. I decided to revert to an ordinary bulb as I have been a bit uncomfortable that the HID light was dazzling other road users, and I rarely drive at night anyway, plus didn't fancy the cost of buying a new ballast unit. Anyway, to cut a long story a bit shorter, when I unclipped the bulb holder clip to fit a standard bulb, the clip pinged out and seemed to have broken the plastic groove in which it was held by a small grub screw.
Just to make life even more difficult, the b.....y clip disappeared off the face of the earth! After about half an hour it dropped to the floor having tried to hide somewhere in the innards of the bike. B.....d!
Anyway, the problem was to refix the clip to the headlight shell in a way which allowed it to swivel on its hinge without falling out due to the broken groove/nib in the back of the plastic headlight unit.
Afer trying various bent washers which wouldn't both hold the spring while still letting it swivel hingelike, and rapidly tearing out what little hair I have left, I had a brainwave.
Got a piece of copper wire from some old 2 plus earth electrical cable, cut a short length and wound it tightly round the hinge end of the spring clip, but leaving a small loop sticking out in the middle for the screw to go through.
Then screwed the clip back onto the headlight through the little loop. The spring clip was firmly fixed yet able to swivel perfectly. Light bulb in and firmly fixed.
I'm feeling slightly cocky about this wizard fix and needed to share it and hopefully win lots of praise.
The lesson from this is...as well as gaffer tape, always carry a length of copper wire around in your emergency repair kit!
