Here is a picture:
Looks very similar to the old or maybe
Here is a picture:
Looks very similar to the old or maybenew style accessory socket connector.
Well it's not like that on the newer bikes. Its a smaller connector. But there's nothing wrong with using the same connector in more than one place - hence my confusion.
They changed the plug / socket at the back in about 2006. Previously the 1100 / 1150 leads that could be used to add extra accessory sockets could be used on the 1200. Later 1200's can't use the older leadunless you chop the end off and attach it to a centech (or similar) fuse box, or add a fuse and go direct to the battery.
Aha... could be useful for an retro fit as the new socket wiring is a bit puny.![]()
, bought a new unit and hey presto. My controller failed about a week ago, bought a new unit and hey presto.
From what I can make out the bike starts up at 100% pump efficiency and then cuts back to 80%?
Is this purely to prevent filter changes? Why not just fit the fuel filter outside the tank?
I am in the process of stripping the old controller for the connectors to rig up a bypass in case of another failure.
There was zero corrosion by the way, even under the resin on the controller.
