Build your own
Hi,
Here's some I "produced earlier" - made sides and a top box.
If it helps here is the breakdown of dimensions and cost for the the 2 side boxes. Mine were made to be just inside the size of my bars, when mounted on Givi frames.
I made these 2 side first and followed on with the top box.
For info the cost of the side boxes was as follows -
Sizes - Length 520 mm @ Height 350 mm and I made 2 widths of 180 mm and 200 mm to accommodate my exhaust box.
My 2 Givi inner carry bags fit inside each.
1- Aluminium cut to size and delivered - panels 2 mm and angles 1.6 mm = £112 - [ this price could be reduced by finding a local supplier and if you wanted to cut yourself]
2- 4 latches = £16.60
3- 8 steel corners covers for lids = £8.90 - Focus or Wickes
4- 4 Padlocks = £ 9.99
5- 4 Handles = £6.00
6- 8 Steel Ball covers for base corners [65 mm 3 legs] = £ 6.40 - ESR Components Ltd -http://www.theelectronicsshop.co.uk/Products/Hardware.htm [ corners ]
7- 8 Bolts for lids corners = £2
8- 200 pop rivets = £ 4.
Total £165
Plus silicone and tape etc.
Tools -
Sharp drill and centre tap, clamps, old surform [ found you could "plane" the Alu to adjust final size if required if required.] Pop riveter.
Here are some pics.
Cheers,
Mac
