Ok so the bulb warning light comes on and I find the small pilot light under the main beam is duff.........now I am sure there must me an easy way to remove it and replace but having rather large hand I can't see how.. It would appear various bits of the bike may need to be removed unless I come across a group of trained ants.
Any advise most welcome before I get my tools out
tilt the screen back, take the 2 bolts out at the side, un plug the two main plugs into the pod at the back, lift the pod 1/2 and inch'ish and it comes of a peg then will move forward with a tilt under the screen, then you can get your hand on the side light plug, just a rubber plug that pushes in, so get hold and pull it out, don't worry it is always hard in, replace in reverse
