Caberg Justissimo
  • Thread starter Thread starter guitarman
guitarman
Bought one of these from Wessons on Saturday for £150. First impressions are very good.
Comfortable and as quiet as my old X-Lite. The drop down dark visor is excellent and the general finish is excellent. It's got a gold stamp which is unusual for a flip front and it's remarkably cheap.
The only problem is that they don't do it in light colours. No-one wants white helmets these days apparently. Not sure I agree with that.
If you're in the market for a flip front then I'd try the Caberg.
Dick
I got one the other week Dick - saw Fritz with one and thought it looked excellent - very impressed for the money.
Well vented (You found the sliding bit on the top of the lid yet?)
Dark visor is great, wind noise dramatically reduced and comfort is very, very good. Found one problem though - me and SWMBO wear the squidgy earplug/autocom fittings and found them unbearable so have decided they will stay with the Arai.
Bit of a naff helmet lock fixing - some tea leaf could just snip the hook off with no damage to the strap though - will have to have another look at that.
Visor took a large piece of road the other day which has left it badly marked but thought it could have been me mush :-(
All in all, I'd say 9/10!
Mark
Throw the GS screen out and fit a Cee Baileys, turbulence gone.
-----OR ---- Take a jigsaw and enlarge the cut above the headlight till there is 1" of clearance between the silver bit and the screen, finish it of with a dremel tool, this lets the air go through top and bottom evenly and stops the turbulence at the top of the screen.
Sherpa did this on his and says it works a treat and he's a big bloke.
HTH
I did find the top ventilation slot John. Although it was bugger all use today. I just did 200 miles in the most outrageous temperatures. It was actually cooler to keep the visor closed as it was like having a hot air fan on your face with the visor up.
Helmet performed really well though and that drop down dark visor is simply brilliant.
9/10 (I'd have given it 10 but I couldn't get it in white and I prefer
a double D ring fastening as the tension is always just right.
Dick
