Hi
I finally fitted a PCIII that I bought at the NEC. My bike is 2005 stock apart from a BOS silencer (with DB killer in place).
The nearest map I decided was the -506 one:
06-07 BMW R1200GS Adventure European Model *Advanced map*
Stock cat in place, Akrapovic Racing Slip On (Db Killer Removed)
Stock or aftermarket air filter
Left cylinder is fuel table 1
O2 sensors disconnected
However, the bike seems to run pretty much the same, or maybe even slightly worse. Nothing obvious, just seems to lack a bit of the oomph the BOS seemed to give it.
It is a bit of a pain for me to switch maps (logistics of getting the bike near a computer), so I wondered if anyone had any good suggestions of what map to try next. Is there any obvious logic to what would be a good initial map - e.g. can you tell me I need one that generally has more fuel at X rpm, less at Y rpm and no change at z rpm?
cheers for any help!
Darren
Darren
