BIGPAUL
Just changed the above and what a differance it makes
Thought i'd pass on a couple of tips to anyone thinking of doing the same
If like me you can't gain access to the spring (piston was stuck inside the barrel) get a paper clip and insert into small hole at top of the barrel and give it a good shake,rattle and roll this should free the barrel giving access to the spring
If you get the adjuster from Motorworks then you will need a 15mm spanner to install and a 17mm to remove the old one
Good Luck
BIGPAUL
Good Luck
BIGPAUL
