Cam cover O-ring size.
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
Gents,
I need to order some Viton O-rings for another problem involving QD fuel connections and while ordering from simplybearings.co.uk; I want to add these cam SPROCKET cover seals in with the postage (one is weeping oil).
What is the size of the O-ring for the cam cover
on my 2002 1150GSA model?
PS: I can edit the post, eg. Adding SPROCKET but, how to edit the subject title?
Patria o Muerte
Are you able to tell me the size of the viton o rings for the QD connectors please mate?
Sorry I’m unable to offer help to you
Not immediately Spangle, it is the fuel QD on my Harley that I urgently need. So want to order other seals for beemer in the same postage.
I need to find what you are looking for.
Patria o Muerte
Maybe Realoem lists size of cam-cover o-ring.
QD o-ring: A friend told me he used the part code ref: AS568-011. Haven't used it myself yet.
For the fuel line QD.
OD: 11mm
Thk: 1.5mm
I used a Vernier caliper so the measurements should be accurate enough.
Use Viton (Dupont) material.
Sent from my MI 9 using Tapatalk
