Came across this Top Case from Triumph dealer.
Looks like it has the same fitting to be compatible with a Givi base plate, if that’s the case it’s a cheap good quality box for any bike if you don’t mind the triumph logo not matching.
Might be worth putting a link in the bargains section 👍
Triumph metal boxes are made by Givi (as are the ‘factory’ boxes for: Moto Guzzi, Royal Enfield, and many others) and should fit straight on the Givi base plate. You can always put a sticker over the logo if it bothers you.
Hmm could it fit on to a 1300 GS?
The Triumph box is made by Givi but doesn't fit the Givi plates. The locking latch is about 10mm further forward on the Triumph boxes. It requires moving the locking base forward on the plate and drill two holes then Use the original bolts to reposition it. It takes no more than 10 minutes to do.
You will also need to buy a Givi lock and key set for the top box (£ 30 or £40 ), new Triumphs come with spare lock barrels and if you look on the website it states that there are no locks with the box.
Still a hell of a good saving though
This (y)
Bought one to go with the new Givi panniers on the Stelvio (they come with a spare lock so you can put it in a Givi Top Box )
Box which appears visually identical to the GIVI item (cost under £100 new from Lings ) bar the mounts and having Triumph on the lid .
I was aware of the mounting being slightly different and it is correct (the rear mount is 20 mm further back on the base of the box ) I left it alone and instead moved the front mounts on the GIVI plate 20mm forward . This solves the mounting issue BUT the lock assembly is different and Triumph use a smaller diameter lock with a completely different fixing method .
Triumph only sell a matched set of three lock barrels and keys for panniers (or supply them with a new bike coded to the ignition) and they are well in excess of £60 from a Triumph dealer and it means my panniers and top box would have mismatched keys .
Givi sell the complete lock and upper assembly that holds the lid shut and incorporates the lock ( GIVI Z8024MR ) it is available but includes the locks and keys which I do not need .
As a temporary fix I took the upper lock assembly off the Trekker Outback 58 litre top box on my GSA , swapped in the spare lock that came with panniers and then fitted the assembly into the Triumph (GIVI ) box.
I will find either a damaged box over the winter to cannibalise for the required parts or bite the bullet and buy the genuine GIVI part which is less than £40 .
Even then it will still be a cheap top box coming in at less than £140
You only need to change the locks if you want it keyed alike. The Givi locks work fine if you use their supplied key.
Triumph sell them without keys and the fitment for the Triumph keys is completely different from the Givi ones, they are not interchangeable
You get the keys/locks supplied when you buy the bike
So if you buy a used Triumph Tiger make sure it comes with the originally supplied keys/locks
Oh, it seems I've misunderstood. I was under the impression we were talking about Givi boxes on the Triumph rack? Givi boxes come with locks and keys, the Triumph boxes don't.
Yes if you change the rack and add a Givi fitting base plate. I’ve got a Givi box on mine ( was on a guzzi before.
