60 ish to 2000 ish sounds about right for the rear. Front should read around 30 to 1100 ish.
sounds like you have lost communication with the potentiometer on the front shock.
Stripped a rear shock a couple of days ago to send in to MCT for rebuild and never given this any thought before but in an emergency there are 2 grooves for the snap ring to sit in.
If in your situation the lower snap ring groove could have been used giving another 10mm of preload. ( about the same amount as going to 2 helmets on the ESA)
A bit late now.
A bit late now.
