- Joined
- Jan 6, 2002
- Messages
- 12,704
- Reaction score
- 1,323
OK...offside carb started to weep a little where the cork gasket of the float bowl mates with the carb body. No problem there.
At roadside removed and re-attached..no joy
! Just to make sure the petrol levels were the same in both carbs etc ..took off the nearside float bowl and nipped the bugger putting it back on
Ordered three ( always like a spare
) cork gaskets from Motorworks which came today. Replaced both sides and STILL leaking at the gasket face
Everything is clean and not warped etc..should just be a simple action of replacing the gaskets and all should be well with the world
Had to stop as had a new knee before xmas and very recently spine numbers L3 L4 L5 and S1 have gone AWOL so bit crippled at the moment to say the least
Any ideas for a repair ?
Motorworks have kindly agreed to send two replacement freebie gaskets out to me but I don't think this will be the cure as currently leaking even trying all the three new ones today. Carbs arn't flooding and floats cut off as they should ( petrol is about 5/8th of an inch from the top edge of the float bowl when I remove them - pic looks a tad wrong as I spilt a bit posing for the camera
Bike starts/runs/cruises at 100 mph if I want the R100rs to etc etc
Few pics....
) cork gaskets from Motorworks which came today. Replaced both sides and STILL leaking at the gasket face Everything is clean and not warped etc..should just be a simple action of replacing the gaskets and all should be well with the world
)Bike starts/runs/cruises at 100 mph if I want the R100rs to etc etc
Few pics....
