Carier Frame .....Fractured
dr nosh
Jamaica Inn
Tonight discovered the pannier frame bracket on the carrier rack broken away. R/H side rear.
Stripped the frames and rack off. Bit of a piss poor original weld. No, or very little weld penetration to the parent material :mad:
But, wow. I quite forgot what a pretty little rear end the R80ST really has.:)
Now need to find somebody with a TIG welder who can do a small and neat weld.
I've got an early rack with the R/H pannier only, need to make lug and weld it on to left side.
Too little time
Doesn’t need to be TIG welded. A perfectly good result could be achieved with gas or MIG - it’s only mild steel.
