This morning i received new software from carpuride.
The problem with the wonder wheel is solved.
Thanks Carpuride for the update great service center.
I can recommend Carpuride W702BS for the BMW R1300GS Adventure it,s working fine .
Everyone happy days and a great 2025 stay healthy and keep on driving
Morning happy to send you my answer from surinam.
This is what is get it realy sovelved the problem.
Yes it hart to get the sd card in on the motor bike but with some rest it willbe oke.
See massage from carpuride.
Hello,
Sorry for the trouble caused to you.
The attachment is the latest MCU software, and the following is the software upgrade steps, which may solve the problem.
(1) Download the software to Windows.
(2) Insert the TF card into the card reader, then insert the card reader into Windows, and format the TF card on the computer, the file format is FAT32. A 32GB TF card is recommended.
(3) Copy the software APM32F030.bin to the TF card. Please note that you cannot add or modify characters to the name of the software. If the software name contains characters such as (1) or (2), the upgrade will be unsuccessful.
(4) Pull out the card reader, take out the TF card, power on the Carpuride device, and then insert the TF card into the Carpuride device, the startup screen will be automatically updated.
Sincerely,
Arie Blom
Follow-up the steps it will work.
Tip use a small pincet to put the card in.
Don.t forget to format you sd card to fat32 format not the fast way take the slow one.
If everthing is oke the update start direct after powering up.
Remove the card after update and restart the system.
The update willbe succesfully.
Use update
APM32F030.bin
Regards Arie Blom
