I want to remove the cat from my header system. I think I can get a welding job done one the system so there should not be a problem just cut it open and remove the core and then make good with a weld. My question is can the induction system cope with this without a total remap of the injection system? I don't want to do this if it involves fitting a power commander and dyno time. Basically what I am saying is its a doddle to do it but what is the knock on effect to the combustion situation? Last thing I would want to do is run the bike weak and burn the exhaust valves and piston tops out
Whats the heads up on that job?
