Chain care and lubrication
RDub
Member
Berkshire
Hi - what's the best way to look after the chain on a DRZ?
I use it on the road and green lanes.
I'd appreciate your advice.
Cheers :comfort
When I used my DR-Z both on the trail and for commuting to work, I used to use two chains.
One was on the bike and the other was in the wash!
Alternatively, use the very best chain you can buy. After a trail ride, jet wash its full length to physically remove dirt and crap. Allow it to dry; then apply a health dose of decent chain lube.
Greg
Or
Clean the chain of all crap,then fit a scotoiler,have one to two drips a minute set up and have a superbly oiled chain you wont have to adjust much and it wont like with chain lube pick up all the grit etc and make a grinding paste on the chain imho...........:thumb2
used this on my chains before with good results, doesn't pick up road shite as much as other sticky stuff:
Mmm, interested now! :D
I s'pose the reservoir could be mounted neatly out of sight - where's is the vacuum pick-up point on the DRZ?
Didn't realise that a single cylinder bike required a vacuum pick up pint? Let me know when you've balanced the carb.......
You could get rid of the air injection gubbins & possibly use the vacuum pick up on the top of the carb that would now be available?
Thanks for the advice.
I've got a scott oiler on my other bike, but I don't want to use one on my DRZ because it could get damaged or torn off when I am green laning.
I will have a look at the WURTH and MOTOREX products and pick one of them.
